PDF - Vector A3 Psychrometric Chart
          2024-1-21 10:45:23
Download:
PDF vector lossless version.
Printing any size of drawing with vector format PDF can ensure smooth edges of text and lines without jagged edges.
Copyright Statement:
Software Author Kelvin.Wang authorized user: Use this software and the final result document without the need to contact the author for authorization; The high-precision psychrometric chart design results produced by this software can be used for all commercial and non-commercial purposes without any cost (All copyrights of hvacolPC belong to Kelvin. Wang), and the software author does not assume any responsibility. You can use hvacolPC for work, design, learning, teaching, research, paper creation, presentation slides, and other purposes other than reverse engineering. You can also freely distribute the complete hvacolPC software package, but you are not allowed to make any form of modification or renaming to the hvacolPC program, interface and user manual, author copyright statement, logo style, etc. hvacolPC can coexist with any other auxiliary design system in the AutoCAD environment, but it must not be packaged into other software as part of other software. When using partial screenshots, it is not necessary to retain the logo of hvacolPC, but it should be mentioned in a certain part of the document that the psychrometric chart screenshot used was generated by HVACOL Psychrometric Chart.
